Small indoor drone or heli for Jumper T Lite multiprotocol
I have a Jumper T Lite 4IN1 multiprotocol radio. I'd like to bind it to a small indoor flying thing. The kind that usually come with the tiny little controllers.
Has anyone had any luck with this? If so what model of drone/multirotor/heli did you use? Was it hard to setup?
For the heli it would need to be flybarless and collective pitch only please.
...Has anyone had any luck with this? If so what model of drone/multirotor/heli did you use? Was it hard to setup?....
I have successfully flown several flying things, a quad and a small helicopter, with my multi protocol Tx. I got the flying things from Banggood. They do a decent job of documenting what protocol the flying thing needs. Knowing the protocol is critical, once you know it, the setup is fairly simple, at least it was for the ones I tried.
If the flying thing is documented, the setup is no more difficult than any other plane. Flysky and Spectrum compatible stuff is easy to setup. Frsky stuff can be more challenging, way too many versions. It can be done, I’ve done it, just more trial and error.
