markfickett
I painted my FliteTest planes! Rust-Oleum spray paint, matte base coat with gloss color coat + gloss clear coat.
I didn't end up needing to sand for good adhesion even on taped areas. I had some dollar-store foam core board and some lasercut semi-waterproof. I had already been flying the planes for a while, so I masked around all the electronics; it was a pain but worked out fine with the caveat that I had to free up a couple pushrods afterwards. The article I found was unclear on whether sanding was necessary, and was using some more advanced stenciling techniques, so hoping this helps someone looking for a very basic/simple approach!
I did have to stick the (blue painter's) masking tape to cloth a few times before sticking it to the plane or else it would pull paint off, and my masked edges weren't perfectly clean but look fine at a distance.
I took design inspiration from The Balsa Workbench; may main goal was making it easier to see orientation in the air.
