PsyBorg
Wake up! Time to fly!
As I have posted before I am loving my versacopter. It has provided me with a ton of enjoyment from the build process to learning how to tune to starting to run my own little race courses for practice. However I seem to have out grown the flying on 3s aspect and am now ready for bigger and faster.
I know that it can be flown on 4s with the recommended power pack. My problem is once I added lights, a hard wired battery warning system, and an fpv system heat (in my head anyways) started to become an issue. Rather then stress parts and possibly crash with a failure costing a lot of money I decide to upgrade some things over time and repurpose working parts to a new project.
I want to support Flite Test and keep it as much their gear as possible and I know some of this may be out of the normal but this was all about learning from the start when I originally bought the Versacopter. I picked up the 30 amp esc's so I KNOW I will be able to feed this power and not worry about stress failures. I went that high as after a few discussions about what I want to do the 20 amp esc would be right at the border line and they don't sell a 25 amp one.
Here is what I start this project with.
To start I removed the 12a esc's and wired in the new ones as well as mounted them out on the arms due to their size. I ran into some problems when I tried to do the initial throttle calibrations. 2 of the motors would spin fine, one not at all, and the last one would stutter and make weird noises. No biggie, I figured I waited to long in the sequence so I redid the calibration. This time 3 motors spun up fine and the one stuttering one was still there. Ok one ore try. This time everything swapped around. The one motor that was stuttering now worked fine 2 others were working and a different one was now sputtering.
A quick cup of coffee and an instruction sheet re read lead me to defaulting the esc's and starting over. Several attempts at that while trying to learn the timing of all that beeping was enough to make me pull my hair out if I had any to begin with. By this time I was starting to get angry so I left it where the last attempt at defaulting and recalibrating left me with all the motors finally spinning but one is stuck in some sort of braking mode.
End of day one.
End of day one.
