steerable front landing gear?
#3
its a tricycle gear and I want the front to be steerable because there is no rudder on it and I want to steer it on ground even though I might have differential I want that part scale. its ok if there is no easy way to make retracts
#5
Common setups are using the rudder servo to control both rudder and front wheel. So just set up one servo and run one linkage to your front nose wheel. I have no idea how one would do it with retracts if you went that route.
#6
oh, I am not having rudder in the plane. just using differential thrust b cause there is 2 rudders. just wanted a steerable nose gear as a cool add on
