You have lots of batteries for sure! Batteries are expensive in Canada so most guys I know have a pair, maybe 2-3 per power setup and a good charger. Get one that can run on 12v or on 120v and you can rapid charge off your truck battery in the field while you fly.
Flaps aren't really needed for RC planes unless you've got something so heavy that its stall speed gets stupid. And they do really change the flight characteristics, especially because you can't trim them on the fly if one is pulling harder than the other, and you end up trying to stay level with your ailerons. This is one reason I like flaperons, they are just a mix and thus if your ailerons are trimmed, your flaperons should be as well. I would disable the flaps until you are comfortable flying without them, because they are one more thing to go wrong.
I like light stripes on dark, on both wings. Easy to see against the clouds or blue sky. Not so easy at dusk. This lets you see not just if you are inverted, but gives you immediate attitude feedback. If you see stripes, you are banking out, no stripes you are banking in. If you are flying straight away (or towards) and get mixed up, pull up. If you see a flash of stripes, you are coming towards.
I'm hoping my black wing/white fuselage Baron will have the same effect, if I can see the white fuselage on black I'm banking out.
@jross get a pair of US military "Bunny Boots" and your feet will never be cold again while flying. They are clumsy to walk in but for standing or ice fishing they can't be beat.
I'm also thinking of doing a internally lighted foamboard plane as dusk and night are often the times when the wind goes to bed here on the prairies. I like the ones I've seen in the videos. Nav lights and strobes would also be a good idea.
@Headbang 160kph? Sounds like glider weather, weight up an old airframe, find a hill and get out there
