Hey, everyone -- I just went and hooked up a brand new motor and ESC from our latest batch of Suppos. Here's my findings:
I first hooked it all up on the bench with no prop. At first, I was not able to replicate the issue. However, after playing with the throttle for a while, it started making the grinding noise. So, I decided to mount it to a test stand and put a prop on it. I ran it up for probably 2 minutes without a single issue -- I ran it up to full, back down to low....up to half, back down....then let it run at about 10% then back down (since most issues have been reported at low throttle). I cycled the throttle over and over and never had it lose timing. I thought either the new batch or prop being on the motor might have fixed it, but then the first issue finally came when I ran the throttle hard up to 1/4 then back to zero then back to 1/4 a couple times without allowing the motor time to spool down. After doing that about three times, it finally lost timing and shut off. Here's a video.
https://www.youtube.com/watch?v=9wHWEVNs7hs&feature=youtu.be
So, my finding is that, as earlier speculated, this is a timing issue. I tried this with a 2217-950 motor as had the same problem. I'm going to send this info to Suppo and hopefully they can fix whatever is messed up in the firmware.
Garret
