FeWolf
Love my pusher props. keeps cost down, I borrowed the design and modded it for my needs. I used blue foam for molding the open areas, it flexes easy and sanded to fit. The open end is were the pod goes, the pod is press fitted in with slide rails on the inside and rods on the outside. First 3 pictures are the p38.
I finished the booms and fuselage.
the bottom is the Bronco, working on wings with 2 to 2.5 lift, the shape will be held in place with booms and fuselage and reinforced with bamboo rods.
