I know it is repeated all over the net , but still seems inconclusive and sometimes inaccurate.
I understand that when installing a motor and prop on a plane in a tractor configuration you have the ability to reverse the spinning direction, but I want to understand the terms as read when purchasing. Please correct me here. Please don't add to confusion by talking about reversing wires.
Perspective of reader to the motor when determing spin direction- the shaft end with threads facing toward the reader.
Shaft threads are right hand or left hand tightening. Standard thread direction in the US is right meaning right to tight, left to loose.
CW (clockwise) and CCW (counter clockwise) describe the spinning direction not the thread direction of the shaft based on reader perspective .
Motors that do not list a direction are typically CCW?
Threads on shaft tighten in opposite direction on spin direction (as designed and described , not confused with as installed and electrified )
CCW motors will have right hand threads.
Propellers described as spin direction not thread direction. And lettering / numbering on prop facing reader would be the perspective for direction.
Not positive how to convert the LH (left hand) RH (right hand) descriptions sometimes on props to CCW vs CW.
Not sure what the designed direction of a prop is when no direction is listed.
It seems that pusher vs puller is a plane configuration, not a technical spec
Can be very frustrating trying to purchase props when there is no local hobby shop to lay hands on...
