The Mini Telemaster arrived today, and there is both good news and bad news...
The bad news is that FedEx managed to damage the balsa, even though it was double-boxed and there was air space between the boxes to allow for typical damage.
The good news is that the damage is limited mainly to the balsa sticks and I think I have enough balsa sheet on-hand to cut my own replacements if they don't want to replace these broken pieces. And when I say they broke the sticks, they broke ALL of them - none were spared. I'm actually surprised there wasn't more damage to the rest of the kit! One rib was split along the grain, but that's a 30 second fix. I've gotten MUCH bigger problems with my Hobby King kits.
Also good news, the quality of the laser cutting is top-notch. Many pieces just need a light breeze to make them fall out of their original sheets.
The kit also came with a lot of standard hardware for assembly, even the wheels. However, these are a bit small for the grass I'm expecting at FTFF so I ordered a couple larger sizes to take along just in case. Note that they also include a check list for all items included with the kit. There are a couple errors, but overall it really helps to make sure everything is there and ready.
Since the parts are literally falling out of the balsa sheets, I'm thinking about taking them all out and "staging" them - putting all the wing parts together, tail pieces, fuselage parts, etc. This would help when we start construction, so I'm not digging through all the pieces looking for a part that my dad has on his board, or worse yet shuffling the parts around and accidentally losing something in the grass!
Also, now that I have the plans I can start designing the mounts for the floats. I want to design the parts and get them cut out while I'm still home, so I don't have to take the bandsaw to FTFF just to cut a couple pieces of light plywood. I'll line up the plans against the HZ Super Cub floats jut to make sure everything looks Kosher.
