Is this a real plane? Or a fantasy one.
its a art drawing, just a "fantasy". Im not totally true to the art paintings either, some things cahanged a little for easyer make in foamboard, and because i wanted. So.. a dual fantasy
Lot of work to get the holders and floats in place in correct angles. I dont know what measuretype i havent used
ha,ha. The last parts the rear of fuselage was infact not as difficult with alligned the thrust- tube with laser, and then adjust the fuselageskins to fit it.
This is perhaps the worst build ive done. Its too many things to need be correct together, and look alike with the paintings, at least some...
As the floats.... that who is on pictures, will not have enough boyance to get a plane as such to float. More or less would been a submerged plane type
Center at top rearward isnt done yet though. AND, i forgot doublecheck some measures on the floats when glued on.... they came approx. 25mm to far forward, and in my calculations, it the wouldnt be best possible on CG balance. They need adjusted rearward.
In my first thought, i planned make the wings detachable. That will not happend, and i also willmake the box-wing type... mainly beacuse the wing aspect ratio. I want a bit more area of wing. With the box type, it will get some more area, as a biplane effect.
Model is beginning to show its designs at least...with wingspan of 1200mm...
