leaded50
my way to strengthen 1 thickness foamboard and make a nice Trailing Edge on wing.
1. i cut out a "deep" V triangle in the TE edge as wide as the thickness of the foam, and remove the cutout. That leaves only approx the paper on both sides back on the end.
2. hot glue into the cutout, and edges pressed flat together with a alu stick/ or other object, squeezing out the extra glue..
(can also be used other type of glue, but then needs taped edge till dry..)
3. The "wing"-part is kept at angle at table, eg. 20 - 30 degrees (adjusted to fit) , that gives a more "uniform" shape on upper/lower side.
Held till dryed, and gets a nice shape as on the TE as at picture to right.
