The right prop for climb performance. Re-powering my E-flite Apprentice S.
Hi folks! I think this may be my first post here. I've been lurking for a while and picked up some good info. Thanks for that!
So the Apprentice is my first plane, I've had a lot of successful flights so far, on wheels and floats. My elevator servo died and went full down deflection in flight on me, needless to say the rate at which the plane met the earth was not optimal. I was flying on floats so it soaked the speed control and damaged the motor as well. Oh well, if we're gonna fly 'em we're gonna crash 'em, right!?
So I plan on re powering with the Turnigy G-25 http://www.hobbyking.com/mobile/viewproduct.asp?idproduct=14401
And a 60amp Plush ESC. I want more STOL performance, as I plan on converting to a conventional gear and adding flaps in the future.What would you folks suggest for a prop? It currently swings an 11x8 blade. I don't really want a larger diameter, although when I convert to the tail dragger I could accommodate a bigger diameter. Is there a advantage to swinging a three blade prop? Other than they look sweet? Again, I'm looking for mostly takeoff and climb performance, not looking for more speed. Is this even the right motor? It's available in two KV ratings, 870 & 710, if I'm looking for torque I want the lower rated one right?
Thanks in advance for your input!
