Now it is scaled
@bracesport ,
As is less the control horns, control rods and a little piece of wire for the bungee hook it scales in at 18.45 oz. It came in lighter then I thought it would with all that 3D printing.
NOW , the heavy c.r.a.p.
5000mah 6S Battery 28 oz
Motor, mount & prop 6.7 oz.
200A Esc & ext. BEC 4.95
rx is .3 oz
So total gear to go in is 42.95 oz.
Total weight all loaded up should be around 63 to 65 oz.
Next once all this glue cures I will start placing things into the plane and see if it will balance
. I have a few options if that 5000 6S battery is to heavy , I could use 2 smaller 2200 3S battery's and hook the parallel to each other to get 6S . I know I could also go to a smaller/ lighter 4S setup with the plane only weighing in at 18.45 oz. I have one setup that would give me around 70 oz of thrust and that setup weighs less then half of the 6S one.
