The start of a new project, not that I really need anything right now Hopefully it is a really go fast plane , plan on going 6S and having over 100 oz of thrust.
It worked pretty good in the glider so why not carry on with it. This one anyways my thought is to make motor mount with a locking tab and 2 screws from the back so I can easily change the motor and if it is a different bolt pattern you print off a new one.
Wire view so you can see the huge battery (yellow and hard to see) and the motor (blue) . I want to be able to run a 5mm cf tube lengthwise under the inner structure which shouldn't be a problem but the wing will have to be installed from the top side.
Question to the experts on bungee launching.
I want to also incorporate a mounting plate in the inner structure to mount a hook for bungee launching, where do you put that hook? On the cg, forward or back of it?
