evranch
Hover test results in! I tie-wrapped my wattmeter under the quad with the pack to keep an eye on usage through the tests. It hovers at 9 amps.
Did an outdoor hover test, quit at 3v/cell under load after 11 minutes. This was 1600mAh burnt, just over half the cell. Not warm but neither was the air.
Recharged and the wind was howling so after putting my daughter to bed I did an indoor hover test to the recommended 2.5v/cell under load. 15 minutes and 2200mAh burnt. Slightly warm. The cells rebounded to 3v after resting a few minutes, I'm charging now to verify the usage.
Much below 3v the throttle levels have to be increased significantly to compensate for the lower voltage, resulting in loss of power, higher currents and exponential depletion of the remaining charge. I'd say below 2.8v it's time to head for a landing without delay.
However, 15 minutes is over half the hover time I got from the bulky 7700 LiPo, from a cheap pack that can be slipped in my back pocket. What's more important is that it handles much lighter and still likely flies long enough to perform most single operations without swapping the pack. I was considering doing 3s2p 6000mAh but it probably works better to have a couple slim, easily carried, easily swapped packs than fat ones.
Hoping to take it for a rip tomorrow, draw some surge currents and see how the flight performance is with a lightweight pack.
If you think hovering an 8" quad in a farmhouse spare bedroom for 15 minutes sounds like an exercise in white knuckles, you'd be right. Not much wiggle room, and it's not trimmed all that great because it's usually flown in acro in open spaces.
