Hai-Lee
Old and Bold RC PILOT
Yes the rudder does move from ch1 to ch4 when you go from 3 channel to 4 channel operation BUT the turn always remains on channel 1.Motorcycle on a curve. Lean into it, bring it back out. I keep using motorcycle analoges, but they seem to work for me.
From what we've covered thus far, though, the rudder changes sticks, from three to four channel.
On 3 channel the rudder is the only turn mechanism and if you are not to spiral into the ground you normally combine its operation with a little up elevator.
On 4 channel the aileron is used to roll the aircraft and when a little up elevator is added the turn commences. The rudder is relegated to a yaw control to tidy up the turn and is not necessary but a nice addition.
If you can fly with rudder in ch1 then try a yank and bank with the aileron in ch1 the only real differences you will find or discover is that using the aileron to turn you do not encounter "Dutch roll" and the turns can be far tighter or more rapid but mainly due to the use of the elevator to drive the plane around the turn!
Do not fret about it as it is so very similar that you will wonder why you worried after a few flights. At least initially keep the rates down on the ailerons until you are used ot how much more responsive an aileron turn can be.
Have fun!
