Hi all,
Having a bit of trouble figuring out what to do with this Electrohub Tricopter of mine.
I've tried mounting the battery at the front horizontally, even added a few small lead sinkers, but it's still tail heavy....rear motor gets much hotter than the front ones. Tips backward on the CG when I try to balance it on my fingers.
Any suggestions other than getting a bigger battery (need to anyway as it's just a 2200mAh) and adding more lead to the front?
Specs:
Motors are RCTimer MT2830 1000kv with 10x4.7 props, 30A rotorgeeks ESCs, Naze32 controller, ES3154 tail servo. Booms are 12mmx12mmx325mm. Also carrying a 5v BEC, boardcam, 600mw VTx
Thanks
Specs:
Thanks
