I just thought we could do a little collection on common multirotor problems and how to fix them. Things that get asked in the forum all the time.
Perhaps we can make it a sticky once we have a few problems and their solution listed.
Every time you change something in your setup, test it! Always do that without mounted propellers!
You will make errors and they usually result in the multirotor doing crazy things. Even if it is only a small plastic propeller, getting hit by one rotating at 10.000 to 20.000 RPM will result in more than a few scratches and quite often even require stitches.
Start with the basics
If you are having issues, try to disable as much additional features as possible to eliminate other sources of error. On a multicopter that means to disable autolevel, compass, baro, and GPS mode on your flight controller. Sometimes issues are caused by problems with the sensors or the logic routines. By putting the copter into full manual mode, you can do a very basic determination of whether it is able to fly at all.
Even if you can not fly in the most basic mode (manual, rate, acro, ...), you can hold the airframe in your hand (no props, remember) and see how it behaves. If the motors start flipping out and try to fly all over the place something probably is wrong.
Once you have determined that the copter holds position in acro mode, and that the motor speeds up when you dip the boom, then you can re-enable the advanced features, one at a time from there, to see where the problem is. Start with the accelerometers, since all of the other modes rely on it to do autolevel.
The multirotor instantly flips when I throttle the motors up
This is a very common problem even for experienced builders. The control board is trying to correct the attitude of the airframe, but has wrong information. This will make things worse, resulting in a more aggressive correction - with an even worse outcome. The end result usually is a copter laying on its back, sometimes with a broken propeller
Solution: Check everything your board knows about your airframe.
You can test if everything is alright by picking up your quad, arming it and throttling up. Remember: Still without attached props! If you lower any of the booms, this motor should speed up.
I can not arm my Multiwii / Flip style flight controller
MultiWii controllers require to have the controller input in a specific range. If your transmitter / receiver does not reach the required end points, the controller will simpy ignore the input.
Solution: Make sure your transmitter sends the correct data.
The copter drifts in self-level mode
If your copter drifts when using autolevel, don't try to adjust using the trims on your transmitter. Unlike on a model without a flight controller it's not your job to counteract that movement, it's the FC who needs to do that job. Your transmitter is only telling the FC what you want the copter to do, but not how it's done.
[Bed mode activated, shutting down Balu for a reboot, need to include the suggestions later...]
- Is the board front pointing to the front of the frame and is the right way up? If it is rotated, did you configure the right angle?
- Does the board use the right motor layout? Each type of frame like Tri, Quad-X, Quad-+, etc. require a different layout. Make sure the right one is chosen
- Are the motors plugged into the right output ports according to the chosen motor layout?
- Are the motors spinning in the right direction?
- If all above are true, you can check if you mount the props the right way. Make sure you use CW and CCW props in their right spots and that the numbers written on them point the right way (usually up).
- The MW board by default expects a PPM timing range of 1000 to 2000 us, with 1500 us as the mid-point. By default, the board requires the channel to exceed 1100 or 1900 us in order to detect the "bottom" or "top" of the range, for the purpose of arming or disarming the board (in other words, left stick down and to the right).
- To check those settings, hook your MW board up to your computer and load up the MultiWii GUI program. You will also need to install the Arduino IDE in order to get the driver needed to allow your computer to talk to the MW. In the MW GUI program, look at the channel inputs screen to see what values the MW is seeing from your transmitter. With the sticks centered, the channels should be very close to 1500. With the sticks at their extremes, they should be close to 1000/2000. If they don't at least exceed 1100/1900, that's why you can't arm.
- You should always start the adjustment procedure with trims centered.
- How to configure this on your transmitter varies depending on what transmitter you have. If your transmitter cannot change its channel endpoints, the only other option other might be to modify the MultiWii code, which is a topic outside the scope of this post. For each channel, adjust the top and bottom endpoints so that the MW GUI shows 1000/2000 for the lowest/highest stick position. A common "gotcha" is that on some transmitters, you adjust the top/bottom endpoint by pushing the stick in that direction. So if you leave the stick centered and adjust the endpoint, you have only adjusted the top. You must then intentionally push the stick downwards and repeat the adjustment to adjust the bottom endpoint.
- Next, adjust the center point so it shows 1500 for the center stick position. On some transmitters, you will have a separate setting for adjusting the center offset of the channel. On other transmitters, the only way to change the center position of the channel will be with the trim switches.
- Whatever you do, I don't suggest taking somebody else's endpoint numbers off the Internet and just going with them. The instructions on RTFQ say to set your endpoints at +125/-125, which is Paul's attempt to cover everybody with one simple instruction. But on a Taranis, the right numbers are actually about +/-97. Hook up the FC to the GUI and see for yourself exactly what the channels are at, and work from there.
