Tunigy 9x not binding
DWH
Have a turnigy 9x trying to bind with fly sky 6 channel rx. Both are new. Hobbyking says they are compatable. What are the step involved in binding the tx an rx. Any ideas.
Phin G
On the Rx, there should be a bind pin and a small bind plug which looks like this:
Plug it in and plug in a power source. A light on the Rx should be flashing slowly. If your Tx has a bind button, hold it down whilst turning on your controller. The blinking should stop.
Hope this helps
P.G
Bo123
I don’t think those recievers are compatible. You need a reciever that runs on the same protocol. Check on the reciever if it says AFHDS somewhere.
Site Moderator
There is more than one AFHDS protocol, make sure both the Tx & Rx are set to the same version, 1 2 or 3.
