Sahara54
I received my 9X in the mail yesterday. Loaded up some battery's and turned it on to check it out. Everything worked fine so I pulled the battery and installed my backlight and Smartieparts board. After everything was back together, it worked just as before but brighter. I already read that the receiver should have been bound from the factory. I hooked it up to my BW and powered on. Nothing...Bind light is steady lit but I have no response from any servo. I checked all settings and everything seems correct (Acro, PPM, Mode 2). I tried to rebind multiple times...Bind plug in batt slot, Bind in Bind, ESC w/ fresh 2100 3S, fully chargeds 6V receiver pack. White wires on servo are towards label. I pulled the module on the back and the pins that were not seated correctly. I fixed that, did all the rebind combinations but still nothing. I'm lost right now...I'm gonna try to flash ER9X tonight and order a Frsky module to see if that's the ticket. Starting to think I should've trusted my gut and got a DX6i.
