ManInaShed
A big thank you too FT 1st and a big thank you to all you kitchen table/workshop aviation engineers.
Well I'm a newb to fixed wing and a complete novice at scratch building.
My FT Goblin was kida successful .A little fast for my armature fixed wing sausage thumbs , but with the help of hot glue and gaffa tape gave me a few hours of fun.
However the old Cobra quad motor finally proved why I ditched it. A stall and a snapped fuse.
A hand full of electronics(minus motor) one sheet of FT foam board , a new 3D printer,1mtr of 8mm carbon and a child like grasp of Fushion360 CAD.
I thought I would go for the FT Mighty Mini Trainer but front prop and one sheet of foam and being an FPV kinda guy this would be a problem.
So a pusher was decided on. Oh thrust angles and all that associated with a Bixlar type design eek I'm a neb remember.
A twin boom job it was was then. The mighty mini wing with the MM rudder/elevator with rudder surfaces halved for each surface and 8mm carbon booms.
So far so good a long night with the good old pencil and paper and a CAD package.
Now I realise the fuselage and C.O.G will need to be well foreword of the wing .I am assuming probably wrongly that the distance between the trailing edge of the wing and the elevator should be kept at similar a ratio to the original mighty mini specifications ( the FT M.M.T paper print fuse is on the pic).My changes being a longer fuse compensating for the heavier tail end.
Will the C.O.G be a constant and will the boom length ( I imagine it will) need adjusting ?
Thoughts , advice and ridicule all welcome .
Thanks in advance M.I.A.S.
