Hi guys, this is my first post on the flitetest forums. I have started making a twin twirl autogyro and I must say that I really love it. Thanx josh and josh, plus the flitetest team for the opportunity.. Materials used are a mixture of Depron and foam board. The Pink and white is the foam board, and the Grey is 6mm Depron. The pink foam board did not come covered in paper. I feel this may be a problem during flight. I added some strips of paper to aid with rigidity, but who knows. Next step is landing gear and electronics. I took a little longer than four hours to get to this stage. I guess I am a slow builder.
I plan on using a 930kv motor, swinging a fairly large 10 x 4.7 prop. A 20 amp ESC as well as 1000mah 3s battery. She will be nose heavy partner!
Regards Matthew
Regards Matthew
