last night when i was reading the OP notes.. it did mention about GPS.. to wait up to a half hour for it to sink.. once its sinks then its much faster after that the next time you connect, once the configuration as the satellites are who knows where till it can get a map of them i guess, or whatever signature the satellites uses to talk with teh GPS... so im assuming that time is just to allow for them to pass over..
must be quite of few of them up there if its only a half hour to get a fly by a satellite.
Cutting won't be happening anytime too soon, that's a very long term project
Haven't done much on the hex, been too busy with work and no time to fly. And when I have had time it's been really windy lately. Summer heat is starting to set in as well
But, my friend with the warp sent me a message that he's going to be back in town for awhile and is bringing his TX this time. So I should have a reliable flying buddy again very soon at least for a few trips.
That's great! I'm guessing you guys probably live in a layer of sunscreen due to the heat.
I've started looking over the Brain a little bit, but I'm a bit confused on the layout and how to hook up 6 motors. You've mentioned you really like their tuning, and rate mode... are you running the stable release or are you running some of the newer stuff?
Sunscreen doesn't help all that much out hereBecoming nocturnal, waking up early, siestas and AC are the keys to survival
This time of year I do more building and less flying - it's why I get confused and keep calling winter Summer except there isn't really a good name for what summer is then!
It's all on the hardware page: http://www.brainfpv.com/support/hardware-setup/
Basically to do 6 motors I used the servo ports for motors 1-4 and then set my RX port to "PPM + UART + Outputs" which gives me motors 5+6 on the main plug along with my PPM input and an extra serial port.
I'm running a custom build from git of the latest firmware - I'd rather run the stock but the stock release doesn't include oneshot yet and I didn't want to have to unsolder the jumper on all my ESC's
Other than oneshot the stock firmware should fly pretty much identically to what I'm running.
The official Brain source has oneshot - there just isn't a binary release with it yet. There's a lot of work going on under the hood to cleanup oneshot on Tau (and experiments with some other different ideas in regards to ESC communication and eliminating latency) which Shred (the guy behind the Brain) is pretty involved with. So I'd guess the next release won't happen until oneshot is fully official in Tau.
If you did go hex with a brain first I could give you a copy of the firmware I built. The only catch is I can't build GCS for windows to match. So you'd have to use a recent Tau build from Jenkins to enable oneshot - and you'd have to use the last Brain GCS to edit the OSD stuff.
One of these days I may look into setting up a windows build system...but I'm really in no rush to deal with that mess!
At 6,300ft it doesn't matter how hot or cold it is. If you are outside unprotected you are gonna fry. Snowy, bright days are the worst. I'll blister under my beard if I'm not careful.
I'm still waiting for my new camera and transmitter for my hex to go FPV.
I also gotta figure out how to wear FatSharks and not have them fog up on me. What's the story there?
maybe what the divers do and spit in them would work? now i think about it, i guess that would not work.. different type of environment i guess. maybe they sell a no fog solution for glasses etc that would work.. i do not wear glasses so i do not know if thier is a product like that out there.
shrugs.
