FoamyDM
Building Fool-Flying Noob
1 Problem to rule them all
I have successfully built my Tyro99 kit from Christmas and I have only one problem... I can't get the FC to see the receiver input.
My main Transmitter is a Radiolink AT10. I have the R6DSM, R12DSM, and I also have the R6d set as Sbus receivers.
They are connected the way it is indicated in the build vid by NJ tech
Checks I have done:
I have confirmed with a smoke stopper that I am short free! Everything is installed correctly.
I can see and talk to my FC (all drivers are installed and working.)
I have Confirmed through the FC that the motors all work and are in the correct directions.
Yes, I have bound the receiver properly to the transmitter. I followed the process, and watched the RSSI bars, go dead, then full bars, once connected as they should. I have no way to test the signal so I don't know if there are any.
I have connected all three receiver units in SBUS mode (blue/purple LEDs), the R6D I was using moments earlier that day to fly my tiny wing. (so I know the unit works.)
Something I have not done:
I have not tested video signal, but if I cannot get the quad to respond, what's the point?
No, I don't have FrSky but I do have the Jumper T8SG transmitter, but no SBUS capable receiver units.
Wit's end
I have a BETAFPV 65s lite that I have been taking out and loving, I have been improving in the sim (liftoff) and I want to move up a level.
Please help me figure this out. I am about to turn all my quads into planes.
I will check the specs on the FC firmware and post soon.
Checks I have done:
Wit's end
