Hey guys - anyone able to identify this plane? It's about the ugliest thing I've seen and I was the only person to bid on it at the RC auction - so with no electronics except servos I took it home for $20.
Yep - she's ugly sitting on the workbench too!
Here's some parts from the junk drawer - a mystery motor, 65 amp ESC, and a receiver. That little tire with the white hub is what it came with. That's just not going to work at my field - needs some balloon tires instead!
For posterity, here's the info that I've been able to find about this mystery motor - it should be about 120 watts per pound with a 12x6 prop which should be good for some fun-fly acrobatics. Maybe need some more power for 3D, but that's a good long away ahead of my flight skills at the moment.
View attachment
To make it easier to attach the wing and not get the right and left servos mixed up, I put all the wires into a 7 pin connector housing (pin 7 for the "key" pin to make sure I don't put it together backwards). No need for fancy expensive wire crimpers for these types of connectors either - small needle nose pliers work just fine with a little practice.
Turns out the ESC didn't have a BEC (wasted more time that I want to admit before I figured that out) - so I added a little voltage step-down regulator to the circuit, and put in a FrSky receiver with built-in stabilizer. That little switch inline with the XT60 connectors for the battery is really helpful when binding the receiver too - much easier to operate one handed!
Needed a bigger tail wheel too, but the elevator servo and pull-pull rudder setup was in good shape.
View attachment
Needed to replace the orange covering on the battery hatch - it had bubbled up and fell right off when being handled. So I went with a scrap of checker board I had handy. Sort of fits right into the ugly.
To get her to balance out without adding too much dead weight, I put the motor out a couple inches using a great planes motor mount - very handy things!
So at this point she's ready to head to the field I think.
I hope the balance point is far enough forward - no way to really tell as I'm guessing at the 1/3 of chord measurement for the CG.
Wish me luck!
View attachment
Wish me luck!
