So, i am wanting to convert this little glider i have to RC. Ive done my research and have all my electronics but the 2s batteries i have seem a tad big. I couldnt really find much in the way of 200-300mah 2s batteries. So i was going to use the 2s from my old Gremlin, 450mah 2s i believe. But while i was going through my stuff during some down time looking for things to repair/build and day dreaming it dawned on me that i have a UMX Timber with 280mah 2s batteries. 4 of em!! It would be awesome to be able to use these tiny batteries in the glider. The motor and props i got are very similar in size to whats in the UMX timber. I get solid 6 minute flights with it but with this glider i plan to power up and glide down so the 280mah should have plenty of gas.
Long story short, i need the female end of this connector to put on my esc. But these UMX batteries have 3 wires going to the plug (for balance charging i assume) and my esc has two. From what i see on the Timber is that it only uses the outer wires for discharging. Does anyone know where i can get this plug? Am i right that it will only use the outer two plugs for discharging? Im pretty sure its called a JST-PH 2.0 3-pin connector but google is google and 99% of what comes up are 2 pin connectors for 1s batteries or charging boards.
Now, I do have this charging cable that i dont use anymore (i bought a charge board).
Could i do what i have written in the picture?
Any help is appreciated guys!!
THANKS!!
THANKS!!
