Hey Guys,
In this Thread I'd like to share with you my latest project, the RST Hunter. This Design is a Pusher with a V-Tail to reduce the weight a little bit in the back section and I just wanted it to try out!
I've allready made 2 Pusher Desings. The V2 was actually quite a success, but it still had some issues.
So I deleted all the planes and went from the beginning.
The Wing: It has a total wingspan of 1200mm. It's a polyhedral wing to give some more stability for flying FPV. The core in the middle is 15mm and on the tips 12mm.
The Tail: As announced it is a V-Tail. The stabalizer are standing in 110° to each other. The Tail is over a 8x8mm Carbon fiber tube connected to the fuselage. The pushrods are secured in a strow. I'm using HXT900.
Fuselage: I tried to achieve a nice looking fuselage which provides its functions as carrying a gopro, Pan and tilt for the flying Camera, Battery etc. I had to build my own Powerpod cuz there was not enough room for the FT Powerpod. I will use probably the NTM28-26 1200kV with a 8x6 Prop and 4s.
Here are some pictures to overview my project:
So, now I hope I'll get soon better weather to test it out. If it's done and flying well I will us it as my FPV plane. Tell me what you think about it or if you noticed some trouble which are ahead of me or things I should consider. Thanks!
