Getting no response from the quad, unable to connect to Betaflight.
Trying to use the Vortex Configurator to flash the OSD, and then use Betaflight to flash firmware (Vortex 250 Firmware 1.0.0.52, with Betaflight 3.2.2 )
I press the button on the Fusion board, then power up, and I see a port to the quad in the configurator. When I start flashing it times out, or gives some sort of error (bootloader fail / communication fail)
Any suggestions appreciated.
*Also adding to the problem may be that I recently tried to plug n play a 'ImmersionRC Tramp 5.8GHz A/V TX Module V2.0 for Vortex 250'.
