It is the discharge rate. 1c is the capacity of the bat, like on a 1c 2200mah pack you can only pull 2.2amps. multiply that by 35 and you get a 35c batt max discharge rate. Try to stay far below that max discharge rate, as the batt might explode if you reach it or go above it. This includes max load.Hi, I was looking at my 3s 2200mah battery and read 35c-70c what does that mean? I'll use it with a 30a esc and 2212/6 2200kv motor. will this work?
So to add to the question, does this mean it's not unreasonable of me to want a 70c battery for a plane with a 35amp ESC?It is the discharge rate. 1c is the capacity of the bat, like on a 1c 2200mah pack you can only pull 2.2amps. multiply that by 35 and you get a 35c batt max discharge rate. Try to stay far below that max discharge rate, as the batt might explode if you reach it or go above it. This includes max load.
Depends on the capacity. anything lower than 1000mah I wouldnt reccomend. Also dont charge a batt more than at 2c, just a tipSo to add to the question, does this mean it's not unreasonable of me to want a 70c battery for a plane with a 35amp ESC?
how do I stay below the max discharge rate? are there any videos about it. cuz I can't understand this.It is the discharge rate. 1c is the capacity of the bat, like on a 1c 2200mah pack you can only pull 2.2amps. multiply that by 35 and you get a 35c batt max discharge rate. Try to stay far below that max discharge rate, as the batt might explode if you reach it or go above it. This includes max load.
Servos will normally state how much current they draw as will a motor and it's esc.try to keep it 5a per cell above the peak load of your esc (the burst current) that is my rule of thumbhow do I stay below the max discharge rate? are there any videos about it. cuz I can't understand this.
this is still very complicated to me... my esc can sustain 2c-4c batt, and my servos are typical 9gs will the batt blow up?Servos will normally state how much current they draw as will a motor and it's esc.try to keep it 5a per cell above the peak load of your esc (the burst current) that is my rule of thumb
You are confusing c with s. S is the number of sells. Escs don't care about the,but about the s, which determines voltage.this is still very complicated to me... my esc can sustain 2c-4c batt, and my servos are typical 9gs will the batt blow up?
Thanks for the amazing explanation, you did better than I ever couldDischarge rate == Amps
2200mah battery at 35c means the battery can deliver 77 Amps of current without being damaged. I use the lower end because you will have power spikes that draw more than that and you don't want to overload the battery.
The amp draw will be determined by what the ESC can deliver to the motor and what prop size you are using. I use a Watt meter like this one to see what my power system is drawing: https://hobbyking.com/en_us/turnigy-180a-watt-meter-and-power-analyzer.html
Power (Watts) = Current (Amps) * Voltage (volts).
At 12-ish volts on a 3S battery, you should be able to deliver nearly 1000 Watts of power. That will drain your battery quickly and certainly shorten its life, but it should work. You can use eCalc to get an estimate of what your power system will do: https://www.ecalc.ch/motorcalc.php
so will my setup work while not blowing up? I don't care about the flight time of batt life.Discharge rate == Amps
i'm using a 2212 2200kv brushless motor, a 30a esc, and a 6x4 prop. and 11.1v 2200mah 35c-70c batt.What motor, prop, and ESC are you using? The combination will determine amp draw to the battery.
how is it 35-70c? it should say just one number, do you have a pic o fthe spec sheeet?i'm using a 2212 2200kv brushless motor, a 30a esc, and a 6x4 prop. and 11.1v 2200mah 35c-70c batt.
It means your battery can safely supply 77 amps for an extended time, 5 minutes or so, until the battery is run down....my 3s 2200mah battery and read 35c-70c what does that mean?...
I don't have the spec sheet but i do have the batt pic if you see carefully id says 35c-70chow is it 35-70c? it should say just one number, do you have a pic o fthe spec sheeet?
This battery will easily supply the amps needed for your application.I don't have the spec sheet but i do have the batt pic if you see carefully id says 35c-70c
I'm planning to put this on James whomleys vampire, or a jetworks f-16.Based on that and some safe assumptions, you should be fine. Looks like Max power is about 240 Watts or about 10C on the battery. A 6x4 prop should generate about 1kg of static thrust, so build your plane accordingly. What are you planning to put this in?
