Scorp11157
Btw. Where do you fly fdnyjery. Always looking to get together with someone to fly with. Talk about the hobby. Share ideas. I'm in apopka fl. Let's get together and swap stories/ ideas/crash some planes
some time
I've never had to prep a plane for tape. I don't use a lot of it but if you do it slowly and press firmly and equally across the surface it should work. Don't know how it'd take up the paper though.I have a question for all of you tape experts. I tried using tape over the white foam board and it ended up peeling the paper off of the foam so I have bubbles in various places. Do you peel the white paper off first or did I do something wrong? Do you have to prep the paper first? would the waterproof work better?
I have not had very good luck with paint.
Thanks!!
Thanks!!
I have built and taped about 70+ FB designs, (and painted about 20 others), and the first trick is to tape either before you cut out or before you fold up and glue. Second tip is to have the tape overlap a small amount (approx 1mm). When applying the tape I use a finger to rub the tape onto the board expelling the air as I go. Once the tape is all applied I then rub the tape under some pressure into the FB as this improves adhesion and pushes air out further. Normally you will see a slight colour or shade change caused by the rubbing under pressure process. The scrap around the edges is removed with a sharp knife in a similar manner to the cutting out. When folded and glued, and the plane assembled, I coat all exposed edges with glue to seal the edges especially the paper. Always coat the hinges etc in a wipe of glue as this is where water can really do damage quickly.
I do not prepare the paper first except for wiping the surfaces with a clean rag to remove dust etc. When about to apply a strip of tape I do pull the tape taught and lower it to the paper surface on one end. When the beginning end is stuck down I use the, aforementioned, finger method to lay the tape on the paper and drive out any possible air bubbles.
Painting the white FB is simple as long as you give the paper a light coating of a poly Varnish. When dry you will need to ensure that all exposed foam is coated with a thin layer of glue. Once the edges are glued and the paper is varnished you can paint away to your hearts content.
Just what works for me!
Have fun!
Thanks!!
