ProfessorFate
Figure thrust angles, see pg 2 vector solution, prev what thrust angle
Hi, I have a new wood design for a power pod that will only be used for Mustangs and Spitfires or Hurricanes, all low wing warbirds and will be made out of wood and use blind nuts and be bolted onto a 1/4" ply firewall with blind nuts.
View attachment 56209 View attachment 56210
I don't want to just center it zero degrees and put washers.
Straight true flight, no trim, no washers, what deg R what deg Down?
When you do this, it pushes your prop and spinner off center and it looks crooked; if you leave it zero deg it flies crooked and needs correction.
I have 2 power systems I may apply to this pod and may make a different pod for each motor:
1: The well known "Beef" Suppo 2217 70g 222watt motor using a gws 9x5 dd on an FT Mustang. holes = 23mm
2: Cobra 2820 1170kv 142g 490watt motor with an apc 10x6 e on an FT Mustang. holes = 30mm
There are so many people out there building flying and rebuilding FT Mustangs and Spitfires, some of you correct the thrust angles, I can figure out from your answer, how to make mine from your answer if only in reference to the screw hole spacing on the motor mounts and the measurement of the height of the stacks of washers you used to set it right.
Now if you actually know the angles in degrees, that would be perfect, I can measure that and put it on the wood panel sides of the dedicated power pods I'm building for FT Low Wing Warbirds that have about 40" wing spans and weigh 1 to 2 #.
I don't know, but the picture on the FT article about thrust angle was a lite plane with a small 6 inch prop and they used 6.5 degrees, I could measure that from the picture.
My initial close guess is 4 degrees Right and 4 degrees down, thinking if I don't go too far out it might make it good.
Could anyone tell me an exact answer and would it be about the same for the Beef 2217 with gws 9x5 and the Cobra 2820 with the apc 10x6e ?
Everywhere I look and search where the issue is discussed, nobody ever says anything with any typical numbers for specific cases or pwr systems and models and all I got from the video pic was our flight test guys showing the pic from one view where I could measure and get the 6.5 degrees, but this is a kind of light airplane, the FT Mustang is a little heavier and I will have one Beef motor pod with a 9x5 prop and another Cobra motor pod swinging an apc 10x6.
Be clear and know that I cannot be experimental about it if I want to permanently mount the firewall with the angle built in and the motor set toward 2 oclock to center the prop and spinner, I do know how to use washers and find out, but I am building this now and I don't have an FT Mustang with a pod to experiment with. This is the 1st pod I will make for FT airplanes. I do know how to fly, but my earlier experience with gliders from 25 years ago is not the same as problems with thrust angle that you have with powered planes.
But, I have seen the video of the guy hand launching his FT Spit as it leaves his hand, it rips extremely toward the Left!
