I saw these Pictures of the TGY-11 Ground Effect vehicle.
When I saw these, saw these ducted fans and thought of the Tiny Whoop and The Whoov. and then I remembered I have a busted E010.
I designed this to be able to fit four on a 22"x34" sheet or it can be printed on 11x17 sheets. When I get this to fly I will release a 4-sheet plan too.
The throttle and thrust differential are all that's needed. I ordered and extra board from the C17
Until then I will use the e010 board from the broken model.
My Build- Alpha
Build Notes:
Fix the wing cutout on the fuse.
Add Guides for fuse placement.
Add tail slot in wing top.
Pontoon placement guide.
My Build- Alpha
Build Notes:
