Jaxx,
yes, I did build the landing gear. It's just a strip of 1/2"x 1/16" aluminum.
It was nice and light but a touch flimsy, so I made a torsion bar out of
a coat hanger and mounted it to the main gear with electrical eye connectors
epoxied on the ends and some 3mm screws. The main is screwed into the 3/16"
hobby grade plywood with some small sheet metal screws, and the torsion bar and rear
support bar are held on with telephone wire hold downs with the nail removed
and it's hole drilled out to fit another small/longer sheet metal screw,
and with some plastic tubing around the coat hangars to make for a tighter fit.
Bolt on axles from the FlyZone Beaver complete the assembly.
thatjoshguy,
I see you designed servo cutouts in the rear/sides of the fuselage already,
but you don't need much room in the fuse to hide the servos
if you cut the servo arms a bit short and use longer control horns on the rudder/elevator
to maintain enough travel. If you don't have any spare control wire setups,
that wire from the marker flags and a few cocktail mixing straws work just as well.
It is common to place the control horns where you did,
but most folks will support the thin crossover on the elevator with something to beef it up.
Many people use popsicle sticks, but I went with a half moon piece of styrene I cut
out of .030 sheet stock and glued it to the top of the elevator because my design
didn't favor anything being mounted on the under side. I also cut a similar plate
to stiffen up the lower section of the rudder that you mentioned in an earlier post.
