Wow! It is so impressive to see a project go from an idea to this, in such a short period of time. That's it!; any spare time I have from now on will be dedicated to SketchUp.
That is taking shape Very Nicely!!
Good work on the paint scheme too, looks real classy.
One thing I worry about though, is that it looks like you
attached your tail skid right to the actual rudder.
I can see how that might even give you some ground steering
but the hinges on these foam board builds are a bit of a weak spot.
A few harder landings might cause the hinge to tear
and the rudder to remove itself.
A few small strips of that clear fiberglass reinforced duct tape at the bottom
of the rudder where it meets the fuselage might help prevent issues, for a while...
I like to use that cloth sports tape on the length of all my hinges for piece of mind too.
Its strong, sticks well, and takes paint better than any plastic tapes.
Thanks! My painting skills are rough, but I'll get there. I minwaxed first, then used acrylic craft paint. I'd like to find something to seal it with above the paint too. Maybe more minwax?
That skid will eventually have at least a skewer glued to it, or maybe even a wheel - yes the idea was to make it steerable. Usually I do use strapping tape on my hinges, but I didn't with this one because it was supposed to be a prototype build. Got carried away when it started looking half decent though
I use the gift cards as well (I buy blank white ones). They seem to add quite a bit of strength to the air-frame. I also use them on the inside wall of my power pod to reinforce the foam around the hole for the BBQ skewer. I drill the hole just a little small so that I get a really good friction fit. Then I don't have to worry about the skewer coming out during flight.
Thanks for the ideas! I tried several ways to get the servos into the tail section, but it really is pretty tight in there. Your model seems to be a good deal larger than mine, and my fuselage is just a bit wider than the power pod (as thick as the foam core on either side).
I like the idea of a popsicle stick on the rudder to stiffen it up, so I may try that. It will fit with my current measurements already. I'm trying to stick to readily available parts/materials as much as possible so that anyone can build this model. For instance, I've designed the landing gear to be similar to the other swappables in that it is made with piano wire, but has a poster board cover to get the look right. Still nice and bouncy too.
My last real concern is the wing. In my current design the wing is glued on. I happen to like that, but the more I think about it it may be better to hold the wing on with rubber bands similar to how NewZee has done. The design doesn't change much, jsut glue the wing or add sticks and bands... guess I can leave it as an option.
If anyone wants an early copy of the plans I can post them. Can't guarantee they'll be super easy to follow but if you have a good eye you can probably figure it out. I'll eventually write up instructions, maybe do a build video with sketchup animations
I don't Know Jaxx? That friction fit idea sounds good but,... vibration is a strong force!
"Go Ask Chad" if he wished he used 2 pieces of fuel tubing, or even a double wrapped #32 band,
around his power pod bbq stick exactly 7 minutes into this OEM Flitetest video??
It is a common practice and recommendation to do so now, and has been mentioned
in some Flitetest videos taken after this one:
http://www.youtube.com/watch?v=5A_HJXmwLQ4
The friction fit actually works really well. It takes a little effort to insert and remove the BBQ skewer. In the video, I believe Chad forgot to even put the BBQ skewer into the plane.
So anyway, about these plans...
Aw come on, thatjoshguy LOL!
My whole spank Jaxx post had not so hidden meaning in it related to the/your plans.
Plans? .PDF or it's all photoshop and mirrors.....
Don't keep us waiting,
Think of my puppy!
Fuel tube and #32 bands, josh. tell me I am wrong with a straight face! Dare you!
OH Dude,
think about what you saw, and what you are saying,
VS the first thing out of their mouths on the video at 7 min.
(David was joking about Chad forgetting to put the peg in, BTW, that's why it was funny)
If he had no bbq peg in the plane, the power pod would have took off like a rocket
after tearing itself right out of the front of the air frame, and left Chad's Spit 5 feet in
front of him on the ground the second he launched it,
while his pod spun around like a Ginsu blender on synthetic marijuana.
Seriously, Brother!
Do you think for a minute the sketchy little alignment tabs would hold that pod onto the plane
long enough for him to do the stuff he did in the air before the peg let go??????
ALL of the pull/stress/torque is on that pod,
and that little peg is the only thing that holds it to the air frame.
The tabs only help to align things, and that's all they do, just like the two pegs at the motor mount.
Please introduce me to your science/physics teacher(s).
I want to slap his/her nose right off of their face for not educating you
enough that you just said what you did, and actually believe it.
Oh, Jaxx. I am so disappointed in you right now,
I don't think I could feel any worse if my puppy got run over by a car...
Now get yourself some fuel tubing or #32 bands before you hurt yourself or someone else, would ya'
Pretty please with hot glue on it???
