thatjoshguy
NewZee, the ring connectors are genius. Just a perfect solution, really!
So that's nearly it for the build! Center of Gravity is a lot better now, and should be manageable by moving the battery if needed. Should have the new motor by Tuesday, but I'm going to try both if the new one works well. I'm curious to see how the 24gr HexTronic does.
I really need to nail the landing gear though. I tried something earlier using water bottle caps and those foam tubes you use in the swimming pool, but they were too wobbly and the plane would tip over when taxing. I'm using marker flags for piano wire so they're pretty strong, but not steady enough. I have another idea to try, just need the time to do it.
