NewZee
Well I'm inching ever closer. Got the Y cable in for the wing servos. Fixed the wing and the wing supports, and wired it up.
View attachment 19921 View attachment 19922
Issues have arisen however... namely, it's freaking heavy.
here's the specs:
AUW = 451g w/battery and motor
Wingspan = 40.5 inches
cord = 6.5 inches
total wing area = 263 inches
I have 8x4 and 9x5 DD props. Currently have a 3S 800mAh battery and a Turnigy Plush 18A ESC.
The only motor I have is this http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=2069
I'm trying to use WebOCalc to determine if this will fly or not, but I really do not understand it all yet. Does the weight of the place affect how many amps the motor will draw? I've read about 30 posts all trying to explain this and it is just not clicking yet.
from what I've been seeing in the reviews of that motor, a 9x6 prop will generate about 15oz of thrust at about 7Amps. The motor specs say it is rated for MAX 7.5 Amps. Is that amp draw even across the board, or only at max throttle?
Oh, and the landing gear still sucks. not strong enough to keep it steady. I'll need to fool around with a new design for that, but at this point I'd be happy to belly land it if it meant I could get it in the air!
Maybe its just me but how could you not have tried it!!! I think the best way to see if your motor has the B**LS is to take off the landing gear throttle up and chuck it! I bet it flys!
