mayan
Hope you find a way I trust youIf there is time I will. I only have a 50watt charger which definitely won't support 6S at 3.3 amps , max about 2.2 amps.
If this plane flies, I will fly it, just maybe not Thursday evening!Hope you find a way I trust you.
I have a bet on youIt's almost maiden time. Finishing work in 10 minutes then off to the flying site. I am nervous, this is a powerful plane!!!
I second this! I'd at least like to see a good cobra if not a full vertical tail stand.+1 to what @mayan said.
I also want to see it stand on its tail, I bet you have more than enough thrust on the 6s to do it. 😉
About 80-90% on that fast pass.....now John is going to buy one of those EDFs to replace one in a plane of his, he was loving the power.I understand the maiden isn't the place for a high speed flyby, but how high up the throttle did John go?
Awesome build, @CarolineTyler. Just. Freaking. Awesome!
One of the things about forward swept wings, it's supposed to be far less likely to tip stall.....but I don't plan on testing that anytime soonLooks marvelous! You got enough to see its silhouette pretty well and how it flies. From what I can see, it has a pretty decent speed envelope, so you can cruise around gently until you get the hang of it. Very maneuverable banking, ailerons are probably pretty sensitive, so looks like "less is more" on the throws (unless your trying to do high g stuff). Once you get good with it, I would bet it could do a tail stand or at least a good cobra, just for a flare or maybe continue a bit straight forward. I'm no expert, but I would probably not try to actually maneuver it at high angles of attack, just more a flare or straight shot.
From what I know(and piece together with educated guesses, could be wrong about this), that sort of wing has a symmetrical enough air flow to not stall in high alpha, but with small root chord and wider span up front, and convergence of vortices into a single trail it is probably not so stable or maneuverable at these angles. It's like standing on top of a pole with your arms spread trying to balance. My sliver can turn and maneuver in high aoa, much better than either of my Nutball variants, because the vortexes are splitting into two somewhat symmetrical trails rather than converging into one, so it's like standing on a wide platform(root chord), supported by two strong pillars, with your arms tucked against your sides so hard they are practically receding into your body. Funny images, but its the best I can describe all this nerdy stuff.
Anyway, great looking plane, you've got the space and the support to fly it and grow with it! Looks like a ton of fun, and makes me want to take a crack at a forward swept build some time soon.
That's good. Sensitive ailerons will be easier to handle without that tendency of tip stall. I think its a great looking plane and was worth the effort. For what you want to do with it, I think it is really well suited. High speed passes and clean banks for days, doesn't stall at high alpha or tip stall. I bet it could roll and knife edge if you ever want to try. Maybe some wing over turns?One of the things about forward swept wings, it's supposed to be far less likely to tip stall.....but I don't plan on testing that anytime soon![]()
Same engines in a leaf blower. I saw a kid in 6th grade(back in like 01,02) bring in a hovercraft for the science project his family helped with some. You had to plug it in, but it could hold a person and slide around like an air hockey puck. It was powered by a single electric leaf blower, which uses a ducted fan so yeah, lots of potential for big thrust. They just hog power a lot more than props.@CarolineTyler - I am glad we have that behind us now - well done - I still can't wrap my head around how these EDF have so much power!![]()
John said it was really nice to fly, I had 60% expo on the roll and pitch, he advised upping it a little more on the roll and reducing it a tad on the pitch. So now on 70% on roll and 50% on pitch. That and the upping the timer to 3 1/2 minutes was the only changes I've made. Looking forward to my first flight which looking at the weather forecast may be a while away ☹️@CarolineTyler I loved it, seemed to fly amazing. Like @kilroy07 said now it's your turn. I'll probably buy the electronics missing for mine on my next pay check having had a few large expenses this month, and not on any hobby stuff
Completely agree, I wasn't flying!Going to give you some pointers:
Remember where the sun is, so you either fly above it or below it, not thru it. If you do go thru the sun, close one eye and open it after you have passed so you can see clearly and pick up the shape of the plane.
For landing, keep a small amount of throttle above stall and only back off when your about 6 to 12 inches above the field ready to land, then bring back to off.
Best way to recognize a stall, is when you move your controls and they really are mushy to the command.
Mentally plan your flight and just do it. I coached a student who placed 2nd at the nationals so you can see where my background lies. Even taught a deaf person how to fly.
Completely agree, I wasn't flying!![]()
