Check out this new frame at hobby king
link
Read the review section underneath it lists most of the parts you need. Of course we will help once you get all your bits.
It's going to be hard to make sure you have everything,
For instance to use the power distribution board you will also need some 3.5mm connectors, to attach it to the frame you need 3mm screws and a set of long and short 3mm nylon spacers. To connect your receiver to the version 2.1 or v3 KK controller board you need the male to male servo leads. If your battery doesn't come with the yellow connector you will also need a pack of xt60 connectors. Make sure you only cut 1 wire at a time or you will short out the battery. You will need some 4 and 5 mm heatshrink too and a velcro strap. Almost Everything including 2cw and 2ccw props are in the multirotor section. But good luck getting all the bits. It's almost impossible to buy a complete kit because something is always out of stock.
The board comes programmed in plus mode, if you want to fly in Xmode like most of us then you will need the avr programmer to reprogram the board or use elevon mixing, which I haven't done myself.
The turnigy 9x is the best controller for the money but it's very hard to get one. Last time they were in stock they didn't even last an hour.
Hope this helps.. Feel free to post your full list and I can add stuff you missed out on.
If you are struggling to get all the bits you can pick up some stuff from eBay
