I just finished my Mini Mustang last night. It will be painted today. I wanted to bring up a few points for someone that has never built one of these like myself:
1.) The control horns can be fragile. I busted the hole that the z-bend goes into because I was trying to reset the control rod. Initially I set the servo too far forward (more on that later) and had already gently placed the rod into the horn. Once I realized I wanted to move it there was no easy way to take it out because I had the servo glued in. I cut the z-bend off and was going to make another and broke the little hole. Luckily I had a extra in my parts kits from my Bixler build. I cut the mounting plate off and glued it directly to the wooden supplied horn. It worked perfectly.
2.) If you are not going to use the offered parts kits or go with larger components be ready to think outside of the plans. I think thats probably one of the best parts of this build; you can make it your own. I went with a larger motor and ESC, I didn't realize how much larger until I started to dry fit parts and realized my CG was going to be forward of my wing! I moved the empennage servos much farther aft and it helped balance it out. I still have yet to put in an Rx but will get to it soon. With the larger ESC I had to place it under the Power Pod, it will not fit nicely inside it like the little 12a one does. Because of this I didn't route the motor leads back through the power pod.
3.) The build videos move faster than you. When he says "let this piece dry for XX minutes" I didn't realize there was a jump. This caused me to initially rush some parts of the build. Don't do that, just hit pause. Taking my time this build took about 2.5 hours not including paint
Overall this was a lot of fun. It scratched my "build" itch and makes me interested in doing more. Just be flexible and look "outside the plans" if you plan on making modifications.
-MM
Tight fit without the Rx. I am trying to decide if I want to use a stabilized RX or a feather weight. I found that with the ESC all the way under the power pod I could easily slide the battery in the front opening almost on top of the CG
Low speed 7x3 prop and high speed 5x5 prop. I plan on picking up a 6x4 prop too. It will be painted today like Strega!
