Dummy Radial 9 Cylinder
Part Dummy Radial 9 Cylinder 1.0
Please log in to download
Type
Dummy Radial 9 Cylinder Engine STL
Designed By: Dan Sponholz
This 9 cylinder dummy radial engine is designed to work with the Flite Test Power Pack B/C Pack Radial motors. I designed it to add semi-scale detail to your foam board model airplanes. It prints as a single piece with no supports using basic PLA filament. The dummy radial has pass-thru cooling to provide air flow over the motor and into the airframe for ESC cooling.
The dummy radial is designed to be mounted directly to the motor through my 3D printed firewall. You will need to use M3 x 18mm cap screws (purchase separately) to mount the firewall and dummy radial to the motor.
Print Settings:
Material:
PLA+ (eSun)
Layer Height:
0.20mm
Supports:
None
Rafts:
None
Infill:
20% Grid
Perimeters:
3
Top Layers:
5
Bottom Layers:
4
Author
SP0NZ
Downloads
72
Views
1,657
First release
Last update
Rating
5.00 star(s) 1 ratings
More resources from SP0NZ
Latest reviews
I just took delivery of an ANYCUBIC PHOTON MONO 4K. I am looking forward to this new journey. Thanks for sharing your talent once again.
