FoamyDM - Mara (the Flying Mustache)
Plane FoamyDM - Mara (the Flying Mustache) 1.0
Please log in to download
Type
Build Plan (PDF, AI, etc.)
FoamyDM MARA
Foam Design by:
FoamyDM (Matt Allen)
Plans by: FoamyDM​
Description:
Learn how to Mold Curves into this beautiful Glider! These graceful curvacious flying wing has similar twisting features to the Prandlt-D wing form. And promises to be a gentle flyer.
The Mara is taken from a Balsa Kit, and uses simple techniques to build this graceful Curvy Glider. It also looks like Yosemite Sam's Mustache
General Assembly instructions are included on the plans. For Detailed Construction process and full pictures see the build log.
This resource was inspired by the FTFC20 Classic to Modern Design build Challenge
Designer note: There is no Thermal Decoupler in the design
FREE PLANS Click the Download Button in the upper-right corner of this page
Printing Instructions
DIY Templates
Bonus:
Learn a New Build Technique to incorporate into your next scratch build!
Watch it fly:
Specifications:
DESCRIPTION IMPERIAL METRIC
Length 23 in 508 mm
Center of Gravity 6 in from wing base 152 mm from wing base
Wing Span 72.8 in 1850 mm
Wing Area 428 in2 276128 mm2
Dry Weight 10.5 oz 300 g
All Up Weight 13.1 oz 371 g
Wing Loading 4.41 oz/ft2 92.9 g/dm2
RECOMMENDED ELECTRONICS: None - but if you must
Motor 1806 - 2204
ESC 12A BRUSHLESS
Prop 0605 slow fly folding prop
Servos 1 - 5g or 2 5g
Battery 1300 3S (no motor), 800 mAh 3S-11.1v
Author
FoamyDM
Downloads
296
Views
1,538
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from FoamyDM
