FT Simple Scout XL Firewall
Part FT Simple Scout XL Firewall 2.0
Please log in to download
Type
FT Simple Scout XL Firewall STL
Designed By: Dan Sponholz
3D printed firewall for use with the FT Simple Scout XL. This firewall is designed to be used with the FT 2814-1100kv motor. It will also support any motor with a 19mm x 25mm bolt circle for direct mount, or 44mm X-mount bolt circle.
*If you need other mounting options please contact me.
Print Settings:
Material:
PLA+ (eSun)
Layer Height:
0.20mm
Supports:
None
Rafts:
None
Infill:
40% Grid
Perimeters:
4
Top Layers:
5
Bottom Layers:
4
Author
SP0NZ
Downloads
148
Views
996
First release
Last update
Rating
5.00 star(s) 1 ratings
More resources from SP0NZ
Latest updates
  1. FT Simple Scout XL Firewall
    Increased the size of the wire passthrough holes for better clearance and improved airflow for...
Latest reviews
perfect file. good job!
I have a Scout in the construction phase. This will be great for it.
