XF A-4 Skyhawk EDF
Plane XF A-4 Skyhawk EDF v11
Please log in to download
Type
Build Plan (PDF, AI, etc.)
SPECS
Span: 30 in.
Length: 43 in.
Empty Weight: 27 oz.
Power: 70mm EDF
Battery: 3000mAh - 5000mAh 4-cell Lipo
Flying Weight: ~45 oz.
I highly recommend a 12-blade EDF, but this jet will fly on any similarly-powered fan regardless of the blade count.
Check out the build thread for reference pictures, questions, answers and discussion: http://forum.flitetest.com/showthread.php?26169-I-want-to-fly-an-A-4-at-Flite-Fest
UBERTHANKS to SP0NZ for re-drawing, formatting and all-around "SP0NZifying" my original plans! :D
Latest updates
  1. A-4 Skyhawk UPDATE!
    This is the latest set of plans for my Skyhawk. It is mostly the same, except the thrust tube is...
  2. Update release files to "v8"
    Increased exhaust area Split nacelles in two pieces, added tabs and slots for easier nacelle...
Latest reviews
looks good but the link doesnt work for me could you updat it
Fantastically easy way to experience EDF Jet Flight!!!
I'n the process of building this model. I will stop back and update this rating after final assembly and maiden.
