Well I’m back I install the landing gear support place and the servo tray should be getting 20 minute epoxy or 30 minute epoxy to glue the landing gear plates in
i’m just getting stuff installed once I get my tail services able to mount I should be buying pull pull cables and all the stuff to get them hooked up to the servos and then I should be mounting a motor and buying some land in gear this my friends is when I get pumped I’m at that point in between where I’m just super excited to get done and fly it
I’ve just started cable management I’m using these wonderful little servos just like in the awesome GB build 😉 I’m using high tech HS 65HB servos for the elevator and then a standard size servo with pull pull cables for the Rutter! These little servos are high torque metal geared and they are absolutely fantastic i’ve used them in two other large scale models and they have never let me down there very powerful things!
Moving along very nicely. The pushrods for the elevators R such a hassle. I do like the way they look, but after dealing with a pull pull, quick & easy & redundant is the way to go. U did a good job on the the foam for the elevators.
Thank you sir I really appreciate it by the way if you know how don’t know how to get my servos to go in the same direction even though they are plugged into the same outlet in the receiver
If you need your servo to rotate a different direction this method works... if your servos are able to do it. My really cheap servos can't be rearranged, but my standard sized JR servos can be.
I have a Spektrum DX8. Under model type, I select two servo tail. This puts the right elevator on the elevator channel, & the left on in the AUX 2 port on the RX. I then can go to the servo menu & select which one to reverse if needed. If U have a programmable TX other than Spektrum, there R other ways to do this. Another option is to buy a servo reverser for the one U need to reverse. I've seen 'em here http://www.valuehobby.com/servo-reversing-cable.html & ebay.
