Spitfire76
My build log for the following challenge
https://www.thehangarrc.com/buildoff/
Although I’ve scratch built and flown several FT planes I have never designed a plane before so this will be a first for me. The "HangerRC Build off"challenge ruled out multiple wing and multiple motor designs and so after some research I came across the Bristol M1 which apparently was the only British mono-plane that went into service during WW1. As far as I can tell their are no foam board versions of this plane although there are several balsa ones. The challenge does require a “B” pack motor so I needed to decide on a suitable scale factor. The wing span of the full scale plane is 30ft, 9 1/2 inches so after a bit of experimenting decided on 1/9th scale which means a 41 inch wings span. I found and purchased this old publication about the full scale plane on ebay.
I also contacted this museum in the UK that has a flying replica of the plane and they have kindly sent me scanned copies of some of the original factory drawings.
So far have made a prototype wing.
