1:9 Scale Bristol M1C - The HangarRC 2022 Build off Challenge
Spitfire76
My (not quite finished) Sopwith Pup has the battery mounted vertically on the back of the firewall. Makes a difference. Not sure who I stole the idea from - possibly Josh Orchard? Anyway - on a plane like this it’s a good idea!
That's good to know. How are you securing the battery?
Baron VonHelton
I mounted a battery vertically to save space. You might've got it from me?
:unsure::unsure::unsure::unsure::coffee::coffee::coffee::coffee:
Baron VonHelton
Spitfire76
Didn't that last 5 months go by fast!. I haven't forgotten about this project but must admit had taken a long break working on other builds including @SP0NZ 's Foam Board Wonder and Scout XL which I really enjoyed. I do feel bad as I owe Sam at the https://www.thehangarrc.com some updated build information that allows the battery to be mounted vertically and avoid so much ballast in the nose. Well I finally got around to it and here is the modified fuse core. There is no longer a power pod. The 3d printed firewall is glued into the front 3 formers and this leaves space directly behind the firewall/formers to mount the battery.
Spitfire76
I have not worked on this plane since the last post back in December of 2022 but just found another challenge that will encourage me to work on those design improvements and finally make plans and build information available to the community. Further posts will be in this thread.
