Had another thought on this last night. In addition to spiral vase mode slic3r has variable layer heights. So I figured maybe using a smaller layer height at the top would help with the tricky tip. And I could use a taller layer height for the body to make up for the slower thinner layers at the top...and thicker layers supposedly work better with clear filament.
Well they didn't look any better but the time was actually 5 minutes faster - so I also slowed it down to 40% for the last 1/4" of height or so. And got the best top yet. Unfortunately this lousy makergeeks filament jammed right near the top causing a weak layer that failed shortly after printing.
So I gave it one more try...and busted out a roll of Nylon since there was talk about whether this part would be strong or not. I found that even the PLA parts are pretty resilient (other than the one with the bad section from the jamming filament.) But the nylon one should be REALLY tough.
That's the nylon on the far right it's not as transparent - and you can see some sections where it looks "bubbly" because apparently this roll absorbed a bit of moisture even though I've had it in my dehumidifier
And the very top is still a tiny bit off. But it's probably the best print yet and very tough. Also Nylon can by dyed with aniline dyes. (RIT will work but you need to heat it and it's still not as vibrant. I suggest pysanky egg dyes - they give great vibrant results!)
Theoretically nylon is also less dense than PLA so should be a little lighter...but it's close enough in density that in a part this small and light already my scale can't tell the difference.
