Here's the stuff I'm talking about, but it's possible to find in smaller "hobby sized" quantities as well. Tower Hobbies used to sell it in much smaller quantities - like 25 feet, but I wasn't able to find it on their site. But it's not too pricey on Amazon, and there are other online sellers as well.
https://www.amazon.com/dp/B015NLZ31Q/?tag=lstir-20
One idea would be to put down your bottom balsa spar piece, then put in all the ribs, then glue on your top spar and leading edge pieces to keep things in place. Depends on how you're designing your ribs I suppose. But anyway, once it's all assembled to that point but prior to sheeting the leading edge, epoxy on a strip of tow that starts at the root on the bottom of the wing, goes all the way out to the tip, wraps around, and comes all the way back to the root on the top. As a single piece it's incredibly strong at resisting tension forces. Then put in all your sheer webbing front and back of the spar - and doubling up on the inner 1/3 or so of the wing like
@Piotrsko suggested (great idea btw!). Then do the sheeting over the leading edge of the wing, top and bottom.
In a lot of ways this is sort of a poor mans approach to a high performance glider wing design - it might also benefit from a 3/4' layer of fiberglass cloth over the sheeting, but that could just be unnecessary weight.
Maybe some of the glider guys like
@Craftydan or
@FAI-F1D can help chime in with their experience too.
