jpot1
Slow going. Built the second wing, glued them together with a bit of dihedral and managed to shove the wires through. Removable wing situated. 4 rubber bands holds thing securely.
Since the nacelles are so small I need to feed the wires through the nacelle top and then solder on the xt60 connector to connect with the xt60 connector on the esc. Should be fun!
Next up, soldering followed by mounting the nacelles. Then pushrod/ servo hook ups all around and then the nose which is going to be tough.
