After a break due to family drama (caring for an elder parent across the country is challenging and knocked the motivation out of me for a bit) I'm getting a little time back in the shop now.
So over the last couple days I glued a rough nose block on the front...
And glued some bracing for the wing hold down dowels...
And the cross grain sheeting on the bottom
And starting on the servo rails..
And some final shaping and blocking on the motor pylon...
And last of all I cut a couple 1/16" strips, soaked them in ammonia, and gently bent them around a form made of pins stuck into a thick slab of balsa...
Once the bent balsa dries up tomorrow I'll spread some glue on the pieces and clamp it back into place again, then do some bracing on the inside of the shape.
